Admin
Allows you to administer users and groups. You can set access rights and view system logs.
Users, groups and access rights are all specific to the domain using which you have logged in. You will not be able to login nor use these access rights on another domain.
Users
The screen displays the list of users and the groups to which they belong.
Figure 2.23. List of Users
List of Users
To enable or disable a user, toggle the Enabled checkbox.
To make or remove an user as an administrator, toggle the Administrator checkbox.
Adding a User
  1. Click Add.
  2. Fill in the appropriate details.
    Figure 2.24. Add a User
    Add a User
  3. Optionally, to add the user to a group, click the icon next to the group.
  4. Click Save to add the user.
Editing a User
The user name cannot be edited. To edit the other details, click the user name from the Users screen and follow the process as described in the section called “Adding a User”.
Deleting a User
Click the user name from the Users screen, and click Delete.
Groups
Adding a Group
  1. Click Add.
    Figure 2.25. Add a Group
    Add a Group
  3. Optionally, to add a user to the group, click the icon next to the user.
  4. Click Save to add the group.
Editing a Group
The group name cannot be edited. To edit the users in a group, click the group name from the Groups screen and follow the process as described in the section called “Adding a Group”.
Deleting a Group
Click the group name from the Groups screen, and click Delete.
Access matrix
Allows you to set the access rights for each user. The access rights are:
Figure 2.26. Access Matrix
Access Matrix
  1. AdhocDashboardEdit: Allows the user to create, edit and delete dashboards.
  2. AdhocDashboardView: Allows the user to only view dashboards. The user cannot create, edit and delete dashboards.
  3. AdhocReportEdit: Allows the user to create, edit and delete reports.
  4. AdhocReportView: Allows the user to only view reports. The user cannot create, edit and delete reports.
  5. SignIn: Allows the user to sign in to the Ambience Web Interface.
Logs
You can view logs of everything that takes place on the system. All user logs are displayed for you to view as an administrator, and take the appropriate actions.
Figure 2.27. Admin Logs
Admin Logs
Drivers
This page lists the JDBC driver configuration for databases that have been configured on the system.
Figure 2.28. JDBC Drivers
JDBC Drivers
To enable or disable a driver configuration, toggle the Enabled checkbox.
To delete a driver configuration, click Delete.
Adding a Driver Configuration
  1. Click Add Driver.
  2. Enter the appropriate driver details as shown in the following example:
    Figure 2.29. JDBC Drivers
    JDBC Drivers
  3. Click Save to save the driver configuration.
These driver configurations are displayed as driver suggestions in various other screens where JDBC drivers are used. For example, the Connection Pool wizard displays these driver suggestions as shown in Figure 2.30, “JDBC Driver Suggestions”:
Figure 2.30. JDBC Driver Suggestions
Download the appropriate driver files from the respective database vendors. Place them in the /lib directory and restart the server to have them loaded.
