The Universe section allows you to map a Universe to a specified universe name and then export the Universe in a format suitable for use by Ad-hoc Dashboard and Ad-Hoc Report.
To add a Universe mapping:
To publish the Universe in a format suitable for use by Ad-Hoc Dashboard and Ad-Hoc Report, enter a name for the template in Publish Ad-hoc Template as
Then, click Dashboard or Report respectively.
By default, everyone can access the Universe provided it is saved in a publicly accessible folder, i.e. not in any User folder.
Optionally, to set restrict the users and groups who can access the Universe:
Click the Add icon () next to the user or group to move it
from the Available
section to the Access Granted
section, as shown:
