Event Logs
Logging is a way for a software suite to save any event records within the suite to a file for further analysis later. By logging and analysing events, it can help build a trend of what normality looks like in the environment. Then if anything goes wrong, these event logs can investigate the problem easier.
The Events Log Viewer allows you to view the events that were logged in Ambience. There are filters that allow you to select the start and end dates and filter the desired data to view. The log viewer displays a limit of 500 records. You can also download the log in CSV or JSON format.
| Event Logs | Allows access to Event Logs page. | mod-events-log-viewer |
Log Parameters
There are two panels in the Event Logs. The left panel allows you to select the desired start and end dates, and filters for the log. The right panel allows you to select the desired column fields to be displayed and it consists of two pages; namely “System” and “When”.
Left Panel
There are three types of filters:
- “Exclude Regular Events” filter
 - “Show Error & Warn Only” filter
 - Criteria filter
The “Exclude Regular Events” filter allows you to excludes regular events from the log, such as AmbienceAgenda (e.g., hourly scheduled activity) and MinuteMinder (records server statistics every minute).
The “Show Error & Warn Only” filter allows you to display only error and warning events in the log.
Criteria
The Criteria filter allows you to filter the log according to parameters selected. For this filter, by default one blank filter is shown for you to enter your filter criteria (cannot be deleted) for you to enter your filter criteria. You can add more filters by clicking on the “+” icon.
There are three components to form a criteria; namely the column field, operator and expression/value. The column field selects the column to filter. The expression defines the information to filter. The operator selects how the filter behaves along with the column field and expression.
To create a criteria, click on the drop-down list to select a column. Select the appropriate operator in the centre drop-down list. The default operator is Equals. In the third textbox, key in the desired expression or value. To clear or delete a filter, click on the
 icon. One or more criteria can be added by clicking on the “+” icon.
[Ss]haron
will find “Sharon” and “sharon”.
In the example below, [Ff]ir will find any string that starts with Fir and fir, such as Firing and first.
Since the [ character is reserved, using it by itself will result in an error message.
To use the reserved characters, place a \ character in front of them. In the below example, to find messages that starts with the [ character, a \ is placed in front it.
In the second example, to find messages that starts with the string “[400]”, a \ character is placed in front of the [ and ] characters.
There are other quantifiers that can be used along with the regular expressions, such as ().*?^.
Right Panel
The right panel allows you to select the column fields to be displayed in the viewer. In consists of two pages:
- System - allows you to select the system parameters
 - When - defines when the event occurs
By default, the “System” page is displayed with default fields. You can change the setting by selecting or unselecting the fields in the panel.
To go to the “When” page, click on “System” and select “When”. The fields available for “When” will appear. Select or unselect the fields according.
To generate the events log, select the desired date range and set up the filters in the left panel. In the right panel, select the desired column fields in the “System” and “When” panels.
Click on the “View” button and the events log will appear in the panel below.
You can add the third filter by clicking on the desired cell field, for example, JVMMinuteMinder in the “logger” column. The filter will automatically fills up. By default, the “Equal” operator is selected. If it is not the desired operator, click on the “Equals” operator and select the desired operator from the drop-down list.
Click on the “View” button to re-generate the log. Now the events with selected field are displayed.
