Activity Logs
A software suite that has good detailed activity logs can assist a company to monitor data processing and report generation as well as to identify potential security breaches or internal misuses of information.
The Activity Logs allows you to view historic Ambience data generation and report rendering activities. It has filters that allow you to select the desired start and end dates and filter the desired data to view. The log displays a limit of 500 records. You can also download the log in CSV or JSON format.
| Activity Logs | Allows access to Activity Logs page. | mod-activity-log-viewer |
Log Parameters
There are three panels in the Activity Logs. The left panel allows you to select the desired start and end dates, and filter for the log. The right panel allows you to select the desired column fields to be displayed and it consists of two pages; namely “Activity” and “When”.
The results panel at the lower half of the page will display only the top row during initial launch. The results will appear below the top row after a search is conducted.
Left Panel
To create a criteria filter, select the desired column field from the drop-down list. Select the appropriate operator in the centre textbox. In the third textbox, key in the desired expression or value. To clear or delete a filter, click on the
icon. To add more filters, click on the “+” icon.
Doc[Xx]
will find “DocX” and “Docx”.
Right Panel
- Activity - allows you to select the activity, user, etc.
- When - defines when the action occurs
By default, the “Activity” page is displayed with default fields. You can change the setting by selecting or unselecting the fields in the panel.
To go to the “When” page, click on “Activity” and select “When”. The fields available for “When” will appear. Select or unselect the fields according.
The Run ID is the number of times you have started Ambience. You can filter by run = 1086 to only see logs from the current server session. If you stop and restart, Run ID will be 1087.
Results Panel
The results panel at the lower half of the page will display only the top row during initial launch. The results will appear below the top row after a search is conducted using the parameters from the left and right panels.
The top row consists of several buttons.
View
This function allows you to view the logs with the parameters set in the left and right panels.
Set the desired parameters in the left and right panel and click on the “View” button.
By default, it is in descending order. To view the logs in ascending order, select “Ascending” from the drop-down list on the left of the “View” button.
This function allows you to download the log in the results panel.
Click on the “Download” button and select the desired output format from the list.
The downloaded file has the file name Activity-Records.<ext>.
Predefined Choices
This function allows you to store, apply and delete predefined parameters for the activity log. This will ease selecting the same set of criteria settings each time the same log is required.
The parameters settings of the predefined choices are local and per user only.
To add the current criteria settings as a predefined choice, click on the “Predefined Choices” button from the top row.
The “Local Predefined Choices” dialog box will appear.
Click on the “Add Current” button in the dialog box. The “Add Current” dialog box will appear.
Key an unique name for the current parameters and click on the “OK” button. If the name already exist or no name is entered, error message will appear.
Upon successfully adding the criteria settings, the predefined choice will be added into the “Local Predefined Choices” dialog box.
Apply
To apply the criteria settings of a predefined choice, click on the “Predefined Choices” button from the top row.
“Apply” icon on the right of the desired choice. The “Local Predefined Choices” dialog box will close and the settings will be applied to the left and right panels.
To delete a predefined choice, click on the “Predefined Choices” button from the top row.
“Delete” icon on the right of the desired choice. The predefined choice will be removed from the list. Click on the “Close” button to close the dialog box.
Reset
The “Reset” button allows you to reset the Activity Logs page to its initial settings. It is useful to remove previous settings and start afresh.
To generate the activity log, select the desired date range and set up the filters in the left panel. In the right panel, select the desired column fields in the “Activity” and “When” panels.
Click on the “View” button and the activity log will appear in the panel below.
You can add filters by clicking on the desired cell field, for example, render-docx in the “activity” column. The filter will automatically fills up. By default, the “Equal” operator is selected. If it is not the desired operator, click on the “Equals” operator and select the desired operator from the drop-down list.
Click on the “View” button to re-generate the log. Now the records with “render-rml” are removed.
