Audit Logs
A software suite that has good detailed audit logs can assist a company monitor data and keep track of potential security breaches or internal misuses of information.
The Audit Logs allows you to view the actions that was carried out in Ambience. It has filters that allow you to select the desired start and end dates and filter the desired data to view. The log displays a limit of 500 records. You can also download the log in CSV or JSON format.
| Audit Logs | Allows access to Audit Logs page. | mod-audit-log-viewer |
Log Parameters
There are three panels in the Audit Logs.
The left panel allows you to select the desired start and end dates, and filter for the log. The right panel allows you to select the desired column fields to be displayed and it consists of two pages; namely “Audit” and “When”.
The results panel at the lower half of the page will display only the header during initial launch. The results will appear below the header when a search is conducted.
Left Panel
To create a criteria filter, select the desired column field from the drop-down list. Select the appropriate operator in the centre textbox. In the third textbox, key in the desired expression or value. To clear or delete a filter, click on the
icon. To add more filters, click on the “+” icon.
[Ff]orm
will find “Form” and “form”.
To use the reserved characters, place a \ character in front of them. In the below example, to find messages that contains with the ‘.’ character, a \ is placed in front it.
Right Panel
- Audit - allows you to select the modules, user, etc.
- When - defines when the action occurs
By default, the “Audit” page is displayed with default fields. You can change the setting by selecting or unselecting the fields in the panel.
To go to the “When” page, click on “Audit” and select “When”. The fields available for “When” will appear. Select or unselect the fields according.
Results Panel
The results panel at the lower half of the page will display only the header during initial launch. The results will appear below the header after a search is conducted using the parameters from the left and right panels.
The top row consists of several buttons.
View
This function allows you to view the logs with the parameters set in the left and right panels.
Set the desired parameters in the left and right panel and click on the “View” button.
By default, it is in descending order (most recent items at the top). To view the logs in ascending (chronological) order, select “Ascending” from the drop-down list on the left of the “View” button.
This function allows you to download the log in the results panel.
Click on the “Download” button and select the desired output format from the list.
The downloaded file has the file name Audit-Records.<ext>.
Predefined Choices
This function allows you to store, apply and delete predefined parameters for the audit log. This will ease selecting the same set of criteria settings each time the same log is required.
The parameters settings of the predefined choices are local and per user only.
To add the current criteria settings as a predefined choice, click on the “Predefined Choices” button from the top row.
The “Local Predefined Choices” dialog box will appear.
Click on the “Add Current” button in the dialog box. The “Add Current” dialog box will appear.
Key an unique name for the current parameters and click on the “OK” button. If the name already exist or no name is entered, error message will appear.
Upon successfully adding the criteria settings, the predefined choice will be added into the “Local Predefined Choices” dialog box.
Apply
To apply the criteria settings of a predefined choice, click on the “Predefined Choices” button from the top row.
“Apply” icon on the right of the desired choice. The “Local Predefined Choices” dialog box will close and the settings will be applied to the left and right panels.
To delete a predefined choice, click on the “Predefined Choices” button from the top row.
“Delete” icon on the right of the desired choice. The predefined choice will be removed from the list. Click on the “Close” button to close the dialog box.
Reset
The “Reset” button allows you to reset the Audit Logs page to its initial settings. It is useful to remove previous settings and start afresh.
To generate the audit log, select the desired date range and set up the filters in the left panel. In the right panel, select the desired column fields in the “Audit” and “When” panels.
Click on the “View” button and the audit log will appear in the panel below.
You can add filters by clicking on the desired cell field, for example, identity in the “component” column. The filter will automatically fills up. By default, the “Equal” operator is selected. If it is not the desired operator, click on the “Equals” operator and select the desired operator from the drop-down list.
Click on the “View” button to re-generate the log. Now the records with “main” are removed.
The Audit Log record changes done in Ambience. For changes done to users (e.g., adding users, deleting user or editing settings of users), they are also recorded in the audit log.
To view the logs for the user changes, select the desired date range and add the desired criteria.
Click on the search button and the logs related to Users module will appear. The logs shows the following:
- “when time” column shows the time this record is added to the audit log
- “object” column shows the original name of the user concerned
- “verb” column shows the type of action carried out on the user, such as “Add”, “Deleted”, “SetEnabled”, etc.
- “Info” column shows the details of the action
Add Audit Log Entry
The audit logs are logged from activities from various modules within Ambience. You can add additional log using an ETL step Add Audit Log Entry from the Ambience category.
In the example below, the ETL chainset consists of two ETL steps.
JSON RecordETL step defines the information to logAdd Audit Log EntryETL step adds the information in the JSON record into the audit log
Run the ETL chainset to log the information into the audit log. In the Audit Log viewer, search for the module demo and you can view the log added.
