ETL Management
Add ETL Chainset
Name | Unique name assigned to the chainset that would be used as its identifier. | Y | Text field | Any text. The value must not exist in the current list of names, regardless of status (enabled or disabled) and ownership. The value is case-sensitive. | Empty string |
Copy From | Indicates what template the chainset would be based on. Selecting “Blank ETL” results in using a blank canvass as a starting point while selecting an existing chainset would result in having the selected chainset as the starting template. | Y | Select | 1 value can be selected. Options are: - “Blank ETL” - names of all enabled chainsets the user currently has read access to |
“Blank ETL” |
Edit ETL Chainset
To modify an existing chainset’s attributes, click on the “Edit” icon under the “Actions” column corresponding the said chainset.
Properties | |||||
Name | Unique name assigned to the chainset that would be used as its identifier. | Y | Text field | Any text. The value must not exist in the current list, regardless of status (enabled or disabled) and ownership. The value is case-sensitive. | Empty string |
Enabled | Indicates if the chainset is enabled (selected) or disabled (unselected). | Y | Checkbox | True (selected) or false (unselected) | True (selected) |
Roles | |||||
Roles | List of roles that are granted read-only access to the chainset. Users who have the selected roles would be able to view the chainset, assuming they have the appropriate privilege to the ETL Designer interface. | N | Checkbox | Multiple values can be selected. All roles are listed as available options. | No value selected |
In the “Roles” property panel, there is a search function, as well as Select All
, Select None
and Invert Select
buttons above the role options.
Similarly, deselect the checkbox to disable an enabled chainset. Disabling a chainset also disables using it with the ETL Designer interface for the designated roles. The owner can still access the chainset via the ETL Designer interface.
Open ETL Chainset
Click on the “Open ETL Designer” button to load the ETL Designer.
Clicking on the “Download” button corresponding an existing chainset exports the its configuration, including all its properties, pages, controls and views into a JSON (.json) file. This is particularly useful for several purposes such as keeping backup copies and uploading it in the future. Filename format: <ETL chainset name>.json
Delete ETL Chainset
To delete an existing chainset from Ambience, click on the “Delete” icon under the “Actions” column corresponding the said user.
Refresh List
